Went to my vehicle today (2002 acura rsx) and the power locks would not work, the emergency break light is on even though the emergency brake is off, and the air is blowing hot. I was reading some blogs online in which other people had all three problems occur to their rsx as well but they did not say how they fixed the problem. I check the air and lock fuses under the hood and they are fine. Do you know what the problem is and how I can fix it? Thanks!
Keywords:Electrical
I am not familiar with all three issues happening all at once with only one problem causing all of them. If you now for certain they are related, I would get a “wiring diagram” (see tab to your left. And look for the common electrical points as these could all be electrical.
The brake light can also come on if it is just low on brake fluid. check this.
Troubleshooting Air Conditioning
