Home » Car Questions » Air con
Air con
opel corsa 2005 aircon,Gas is ok compressor switches on and off ,pipe from the compressor to the evaporator is cold but there is no
cold air only air hot blowing in the cab
1 thought on “Air con”
  1. If your car is equipped with a Cabin Air Filter, Check this first. If it is not or it is nice and clean…. your HOT/COLD Blend door actuator is not working and most likely need replaced, this is a common failure part.
    The Actuator is deep in the dash and removal of the dash will be needed.
