1998 Chrysler 300M My brake fluid is disappearing! No drips, drops or spatters anywhere…Could it be leaking into the engine?
The Brake system is a sealed unit and therefore not leaking into your engine. You will need to look closer at the inside of each wheel and look for signs of wetness. Might not drip on the ground but will have wet components. http://www.freeautomechanic.com/brakes.html
