Home » Car Questions » BMW Standard Engine Shifting Problem
I have a 2000 BMW 323i with a standard engine. When the engine is running, the stick shift will not completely go into any gear or reverse. When the engine is not running it will go into every gear and reverse. I can put it into reverse or first gear with the engine off, start the car and drive it that way but I cannot go into second with the engine running. The just started last night.
1 thought on “BMW Standard Engine Shifting Problem”
  1. Your clutch master cylinder/slave cylinder needs to be replaced and possibly your clutch disc/pressure plate also. This is assuming you have already made sure your clutch fluid level has been checked and topped off.
