Home » Car Questions » Chevy Transmission SwapChevy Transmission SwapSeptember 7, 2010September 8, 2010Can I replace a 98 4160e transmission with a 96 4160e transmission from Chevy 1/2 ton pickups?Keywords:Transmission3 thoughts on “Chevy Transmission Swap” Jaxer September 8, 2010 at 6:24 am Yes. Brian Daniel September 8, 2010 at 7:58 am Will there be any problems with the electronics? Jaxer September 9, 2010 at 7:46 am No. You may need to swap a sensor or two on the outside of the case, only to allow the connectors to plug into them. in most cases you will not even need to do that.Comments are closed.previous1978 dodge chatters in reversenextDodge PU 1998 V8
Yes.
