So I noticed that my turning signal was sounding way too fast while driving, I recognized that usually means that there is a burnt out bulb I pulled over to check…and lets just say It gets soo messed up that I wish it was just a burnt out bulb
You see the driving light still works but doesn’t flash in the front, and the rear turn signal works and flashes
but its faster than normal the hazard light works on every other light but the front passenger side
also the instrument cluster doesn’t show a signal for turning right I can only hear the back one over working
I know the bulb thing is not the issue because it will stay steady, soo it has to be some kind of problem from the steering wheel to the bulb…some kind of signal not being sent…a wire issue….Help please !!
The make is a 2003 ford ranger
I you have already tried replacing the bulbs or at least swapping them from side to side. The next step is to obtain a wiring diagram ( see “Wiring Diagrams” tab to your left ) and trace down the electrical problem.
