Home » Car Questions » olds. trans
olds. trans
how do i know if my pcs went out? i was driving down the road all of the sudden it was like i was in neutral no forward or reverse.changed fluid and filter,still nothing. there was no noise or any thing when it happened just kind of like it went into neutral no slip or anything
2 thoughts on “olds. trans”
  1. It would be helpful if you could state the Vehicles YEAR and MODEL….
    Your vehicle would have the check engine light on and have a P0700 code referring to a transmission issue. Using a capable scan tool, there will be at least one transmission code that would indicate a failure, possibly the pcs.
