Home » Car Questions » replacement PCM for 2001 dodge neon has OBD II code p0601
replaced PCM (part# P05293107AJ) with remanufactured cardone PCM (part # 79-3107V) on 2001 dodge neon se with 3 speed auto. trans. and 2.0 4 cyl engine (code c) had dealer reprogram new PCM. Still getting OBD II code p0601 and check engine light still lite. what could cause this? Is new PCM bad?
1 thought on “replacement PCM for 2001 dodge neon has OBD II code p0601”
  1. It is very common to get a “BAD” rebuild computer. Sometimes you will have to go through 3 of them to get a good one. Trust your Diagnosis!
