Home » Car Questions » spark plug and easy out
while tryint to change a spark plug in my only vehical the guys accidently broke the spark plug. Then tryed to use an easy out which in turn broke as well. i dont have the money to buy a new head. i sprayed db blast it has been soaking for a good 3 hours. help!!!!                  95 chevy, cav, 4 cyl
1 thought on “spark plug and easy out”
  1. Try to remove the easy out and use a better one to remove it. Warming the head with a propane torch can help. Worse case, remove the head and use a carbide drill bit to drill it out. Then install a spark plug repair helicoil. No need to buy a new head.
