I am looking for an accurate wiring diagram for my 1999 Chevy Suburban 4WD 5.7L Or even better, if you have seen this problem and have a fix!
If you need a wiring diagram try clicking the “Wiring Diagrams” tab to your left.
If the starter was recently worked on, check to make sure the wires aren’t touching at the stater power wire and the “s” terminal wire.
If equipped with a starter relay, check to see if it is sticking.
Does it have remote fobs, or remote start? I have heard of such things with cars having remotes.
The remote start is causing it. It happened to me and I just cut it all out. Not once has it done it since.
