I have a 1990 firefly automatic, This morning I started my car and it started to putter. I then put it it reverse and nothing and also in drive but nothing. I now can put it into drive and I have to rev it real high just to make it move 5 to 10 kms. Please help me with this problem.
Keywords:Transmission
First, check your transmission fluid level. If it is low, top it off and test drive. If it now functions correctly, check for leaks to see where the fluid went.
If the fluid level is full, you have internal transmission issue and will require a rebuild.
