1978 dodge started relay connections
What does the green wire on pole labeled G connect to? If I remove the wire and ground the pole the relay works and vehicle starts and runs.
UPDATE:
Thanks.  Found the wiring diagram by clicking the tab to the left.  (Its connected to neutral switch)
