To engage the four wheel drive I have to unplug the outer vacume line on the axle shift motor, then plug it back in. What is my problem? Is it the shift motor or something else? I have to do this in low or high 4wheel. Thanks, Big E
Most likely it is the vacuum diaphram needs to be replaced.
Thanks alot. I will get one. Thanks again, Big E
