have a 98 ford escort that just quit running had friend ford tech check and said no fuel pressure replaced fuel pump but still not runniong pump will pulse little fuel but not enough to run car
Keywords:No Start
You will need to reset the inertia switch. This is found in the passenger side under dash at floor under the carpet or in the passenger side kick panel. This needs to be reset after fuel pump replacement. Then check the fuel pump fuse to make sure it is good.
