Home » Car Questions » 1997 chevy silverado
after towing a trailer(running lights not working on trailer)
after I cut off my truck,then restarted, the running lights and dash lights on truck don’t work!Is there a fuse or breaker that controls dash and running lights
1 thought on “1997 chevy silverado”
  1. Why Yes there is a fuse for the dash lights. If you pull out your handy owners manual(usually in the glove box) you can look in the index under “fuses” and it will give you the exact location of all the different fuses. Most likely the trailer has a short in the wiring and caused the fuses to blow in the truck instead of catching on fire… Unplug the trailer before replacing the fuses.
