Home » Car Questions » 2000 Plymouth Grand Voyager
Plymouth mini van the front wiper wont turn on  their is no power going to wiper motor I check all  fuses and relay all working .
How can I find the power wire in the fuse box .
3 thoughts on “2000 Plymouth Grand Voyager”
  1. The best approach would be to aquire a wiring diagram and trace the wiring. Most likely your switch is bad. You can just swap out the switch and see if that does the trick or you can test and make sure power is getting to the switch but not from the switch.
    You can get a wiring diagram by clicking the “Wiring Diagrams” tab to your left.
