Having trouble getting the 4WD to engage. Would appreciate any suggestions or ideas. Automatic transmission/6 cylinder
Keywords:4WD
Could you be a little more detailed. Does a light come on dash? No light? Grind noise? Anything ?
The 4 wd light just blinks. No noise. It is a 2004, 6 cylinder, auto transmission. Suspect it might be the ADD??? Open to any suggestions or ideas that you may have. Have 1996 that is still running with over 300,000 on it! Does not look so good but it sure got us thru the snow this winter so far!!! THANKS!
