Just had the tires balanced to fix a vibration that seems to increase with speed. It didn’t fix the problem, though. Where should I be looking next?
2006 dodge ram vibration
Keywords:Vibration
If there is a vibration at slow speeds like creeping in the parking lot about 5 to 10 mph and you feel it in the steering wheel or in the back of the car, you probably have a belt seperating in the tire and it will need to be replaced. Another sign of a belt seperating is a slight pull to one side.
A U-joint going out could cause a vibration at speed….
