Home » Car Questions » jeep wrangler cpu
jeep wrangler cpu
does any body know how to reset cpu
1 thought on “jeep wrangler cpu”
  1. Disconnect the battery for 10 minutes.
    If it is 1996 or newer and you are just looking to clear codes you will need to either fix the problem or use a scan tool to clear them and if the problem isn’t fixed.. you guessed it, the light will come back on.
