ABS light is lit on dash and blinks continuously. The dash lights parking lights break lights do not work. But if you mess with the headlight knob they all will come on. But if you pull it out all the way like its suppose to then the lights don’t come on. The headlights work but nothing else. The signal lights work when used. Help
The ABS system is seperate from your lights and will require computer diagnostcs. As for the headlights, replacing the dash switch should take care of that issue.
