Hi, my Ford transit has developed a new irregular “knocking” noise from the engine. Could it be the engine mountings? It is 1994 SWB model.
Home » Car Questions » Ford Transit mini bus 1994 has developed knocking noise from engine.
It could be the engien mounting, but not very likely. Most likely an internal bearing is failing. You can remove the belts and start the engine to make sure it is internal in the engine though.
