i have 2003 kia spectra it has a noise coming from the front end ,which sounds like your in a prop plane when your on the freeway. when you turn right it almost goes away and gets louder when turning left or when the front end goes down due to bumps in the road
Keywords:front end noise
This sounds like a wheel bearing to me, you may want to jack the front end up in the air and see if there is movement with the wheel still on.
I have had the same problem on my 2001 Montana Van Many times It is the wheel bearing as the mechanic said ,a pain in the but but its not that expensive to fix .
i checked the wheels everything seems tight no growling and it isnt sloppy
trans axle maybe?
