The Majic fix all for most “Small” coolant leaks is a product called “Bar’s Stop Leak”. I preffer the pellet form that comes in a bottle. Put it in the radiator (not the overflow) and run the engine for around 30 minutes or so. You can drive it if you wish. Let it cool and then check your coolant levels and you should be good to go.
