Home » Car Questions » FEUL VAPOUR CANISTER LEAKIN GAS
TOYOTA COROLLA 93 1.6 LITRE JUST HAD THE FILLER PIPE TO THE GAS TANK CHANGED NOW GAS LEAKS OUT OF THE  BOTTOM OF THE FUEL VAPOUR CANISTER  , I PUT GAS IN AND IT JUST PISSES OUT THE BOTTOM OF THE CANISTER  ANY IDEAS !!
1 thought on “FEUL VAPOUR CANISTER LEAKIN GAS”
  1. I have seen this once before after a fuel pump change but didn’t have time to diagnose the problem. If it didn’t do it before, I would go back over what was touched or taken apart… like if the gas tank was removed did everything get hooked back up the right way or did the return line get pinched…
