I want to know the best way to remove a 3.0 engine from a 1999 Plymouth voyager minivan: top , bottom, or separately? Why?
Home » Car Questions » remove engine and transmission from a 1999 minivan
Keywords:minivan engine
Bottom. You can drop the subframe with the engine trans togather and then seperate them. Why… because it is the quickest and most relvent way to remove the engine.
