Often while I am driving I find that my dashboard indicator for speed ,fuel level,temperature etc will go to zero for awhile them recover to normal after a period of a few minutes. Sometimes recovery period takes longer. Honda Accord cope V6 2001.
Home » Car Questions » Honda Accord cope v6 2001 dasboard indicators problem
Most likely the connection at the back of the gauge cluster itself is bad, you may need to have the entire gauge cluster replaced as a last resort as it may be an electrical issue with the connector or on the gauge cluster itself.
Thank you. It helped a lot !!! I fix that. Sergey.
