It’s a 1998 Wolfsburg. We tried to bang on the starter celanoid and that didn’t help. When we turne the key, it doesn;t do anything.
Keywords:No Start
Assuming you have made certain your battery is good and fully charged, Have someone hold the ignition key in the start position while you check for battery positive at the “S” terminal on the starter. If you see Battery positive at the “S” terminal then you need to replace the starter.
