Home » Car Questions » 1999 Dodge Grand Caravan Sometimes won’t start
When turning the key there is nothing no clicking or sound of a dead battery. Turn the key off and back on 3 or 4 times and it will start and run fine. Problem used to happen occasionally but now is happening more frequently. Almost every time I start the van. Ignition module?? Bad Battery?? Any suggestions greatly appreciated.
1 thought on “1999 Dodge Grand Caravan Sometimes won’t start”
  1. After making certain that you have good CLEAN connections at the battery, you can almost bet on needing to replace the starter assembly.
    A test can be performed by having someone hold the key in the “START” position while you check for battery voltage on the “S” terminal of the starter the next time it won’t start up. If you see voltage, replace the starter.
