It has a broken timing chain, Will that damage the over head vavles, can I skip looking at posible damaged valves and just insall new timing belt?
YES.
Easy to check for damaged valves once you have put the belt back on. Just perform a compression test. All cylinders should be within 20 psi of each other and none at 0 psi.
