tail lights won’t come on i tried changing fuse but it burns out everytime. i tried unpluging the autoshutdown relay plug and the lights came, when i reconnected the plug the fuse burned again, what can be causing this and how can i fix it?
You have a short in the wiring causing a higher amperage draw than the fuse can handle. You will need to trace down the short and repair it.
http://www.freeautomechanic.com/wiringproblems%206.html
