I have a 94 Isuzu rodeo that burning alot of cooling fluid. I have not found any phyical leaks, so I am a little confused as to what is causing this problem.
There wouldn’t be any leaks found if it is burning the coolant. The leaks would be internal and not visible unless you took the engine apart. At this point a pressure test on the cooling system along with a compression test on each cylinder would help narrow down where the coolant is going. I suspect the start of a blown head gasket.
