Yes. After I changed the battery the ac blows cold on driver side. But blows hot on passenger side on my 2003 Chevy Silverado
http://freeautomechanic.blogspot.com/2011/06/2005-chevy-trail-blazer-blows-cold-out.html
Most likely the actuator will need to be replaced. When the battery is replaced the actuators try to re-calibrate. Often times damaging themselves. Quite common with these Chevy’s
HVAC Blend Door Actuator R&R
Automatic
- Less Custom Floor Console Option (D07)
- Remove floor air outlet duct extension (1) from floor duct (2), Fig. 1.
- Disconnect electrical connection at mode actuator (10), Fig. 2.
- Remove mode actuator mounting bolts from HVAC module, Fig. 3.
- Remove mode actuator as an assembly with actuator cam, Fig. 3.
- Reverse procedure to install.
With Custom Floor Console Option (D07)
In order to avoid actuator damage, DO NOT apply power to actuator when it is not installed in HVAC module.
- Remove center console.
- Remove bolts from the center console duct.
- Remove center console duct.
- Disconnect electrical connection from mode actuator (10), Fig. 2.
