Home » Car Questions » check engine light
check engine light
I have a 2003 Ford Taurus station wagon. The check engine is on and I have the following trouble codes P0705, P0122,P1121.P1120. What do I need to do to get this car repaired?
2 thoughts on “check engine light”
  1. http://www.freeautomechanic.com/diagnostictroblecodes.html
    P0705 Transmission Range Sensor Circuit Malfunction
    P0122 FORD Throttle/Pedal Position Sensor ‘A’ Circuit Low Input
    P1121 FORD Throttle Position Sensor Inconsistent with Mass Air Flow Sensor
    P1120 FORD Throttle Position Sensor Out of Range
    It would look to me like the first thing I would do would be to test/replace the TPS (Throttle Position Sensor)
    http://www.freeautomechanic.com/tps-throttle-position-sensor.html
