Home » Car Questions » emergency brake adjust
how to adjust emergency brake  on 1995 geo
1 thought on “emergency brake adjust”
  1. Metro?? Prizm?? Tracker??
    ADJUSTMENT
    Remove both door seal plates and the seat belt buckle bolts at the floor.
    Disconnect the shoulder harness bolts at the floor and the interior, bottom trim panels.
    Raise the rear seat cushion.
    Pull up the carpet to gain access to the parking brake lever.
    Loosen the parking brake cable adjusting nuts.
    Adjust the parking brake cables, so they work evenly.
    Adjust the cable, so when the parking brake handle is pulled, its travel is between 5–8 notches, with 44 lbs. of force.
