Home » Car Questions » Need help with removing emergency brake cable from rear caliper on a 2001 Hyundai TiburonNeed help with removing emergency brake cable from rear caliper on a 2001 Hyundai TiburonJune 29, 2011June 29, 2011Keywords:park brake cableTiburon1 thought on “Need help with removing emergency brake cable from rear caliper on a 2001 Hyundai Tiburon” Freeautomechanic June 29, 2011 at 10:27 pm Select the “Auto Repair Manuals” tab to your left for repair procedures.Loosen the adjuster in hte cable to give you enough room to move the cable forward and through the notch.Comments are closed.previous’94 Sonoma wont startnext1999 Ford Expedition Start Problems
