Home » Car Questions » no back up lightsno back up lightsJune 21, 2011June 21, 2011i have replace bulbs and fuses what might be the problemKeywords:back up lightsElectricalLights1 thought on “no back up lights” Freeautomechanic June 21, 2011 at 2:09 pm Your nuetral safety switch may be the issue or in the wiring to or from the switch or bulb socket.Obtain a wiring diagram and with a multi-meter you can trace the wiring to locate the issue.Comments are closed.previousDodge Caravan/Intrepet rear axle assemblynext94 rodeo cooling problem
