Home » Car Questions » 95 Tacoma starts hard
My 95 Tacoma will start first time right away, however each time thereafter it starts harder and harder, like it is flooding. It will start eventually and it runs smoothly, I’m wondering if it’s a type of gasoline problem. Any advice?
1 thought on “95 Tacoma starts hard”
  1. if the check engine light is on at all, check the codes first!
    I would want to hook a fuel pressure gauge up to see if the fuel pressure is bleeding off when trying to start, may need to have the fuel pump replaced. Or might just have a sticking IAC. Next time you are trying to start it with the engine warm, try pressing the gas pedal to the floor when starting and see if it fires right up quick, if it does, then look at the IAC.
