Was running a little sluggish and thought I was running out of gas. Since then I’ve changed Fuel filter, Plugs, Wires, Distributor, Rotor cap, Coil and now the TFI module. Still slightly misses and has a pinging sound
1989 Ford E150, 4.9l 6cyl
Well, First off anytime you hear pinging this is an indication of improper ignition timing or low octane fuel. Low octane fuel can be cheap/bad/contaminated gas. I would try a bottle of Octane booster first and then buy some higher octane fuel at a different fueling station than you have been using and see if that doesn’t take care of it before going any further.
