Home » Car Questions » 1999 saturn
1999 saturn
my saturn has been burning oil and smoking bad for a bout a month now its starting to really effect the car i dont know what to do
1 thought on “1999 saturn”
  1. Check to see if your oil level is increasing, if it is, you probably have a fuel injector stuck open and this is saturating the oil and making thinner and easier to burn.
    Pull all the spark plugs an see which one/s are wet or real black looking… this would indicate the troubled cylinders. You can then Give it an oil change and swap 2 injectors to see if the problem changes to a different cylinder. If it does follow the injector a replacement should fix it right up. If it doesn’t follow the injector, then you are looking at internal damage that may require a rebuilt of the engine.
