I have a 2001 Pontiac Grand Prix SE,3.1 L engine.The wipers only work on high or
off,no low or intermittant.Ive changed out the Combo switch(turn
signal,cruise,and wiper delay) It still does the same thing.I cannot find a
Relay to the wiper system,but ive heard about the Wiper Pulse Module.Do you
think this is the problem ? Thanks Danny
Yes the pulse module is the problem, it is located inside the back panel of the wiper motor assembly. When you go to the parts store and get a replacement, hang on to the receipt as you may need to take it back…. Why you ask? Most of the wiper motors available at the parts stores are re-manufactured and the quality just isn’t there with these. I would say 1 in 5 aren’t even looked at by the re-manufacturer and simply cleaned up and re-boxed for sale.
So if you install the replacement only to have a similar but sometimes different issue with the wipers, just take it back and try another one…..
While my car is running it makes a knocking noise. Why?
