1999 Ford F-150
my abs idiot light comes on in my truck,what things can I check to see what’s causing my light to come on? I checked the brakes and they seem okay added some brake fluid because the fluid was low.
1 thought on “1999 Ford F-150”
  1. The Four-Wheel Anti-lock Brake System (ABS) is an electronically operated, all wheel brake control system. Major components include the power brake booster, master cylinder, the wheel speed sensors, and the Hydraulic Control Unit (HCU) which contains the control module, a relay, and the pressure control valves. When anyone of these malfunction the ABS Light will come on.
    Reference: http://www.freeautomechanic.com/abs.html
