Home » Car Questions » want start or anything
a dodge 2002 modle 1500 truck quade cab 4.7 liter rse45 trans. Check all fuses, change starter, ignition switch clean battery post and terminals. vehicle will not start or turn over all the sysmbols stays on oil, airbag, check engine, abs but nothing. please help.
1 thought on “want start or anything”
  1. Check for positive battery voltage at the “S” terminal on the starter when someone holds the key in the “START” position. If you see battery voltage then replace the starter. If you do not check backward from the starter to the ignition switch. Don’t forget about the neutral safety switch either. Might want to click the tab to your left and get a wiring diagram too.
