Home » Car Questions » chevrolet blazer
chevrolet blazer
2000 chevrolet blazer will start and run if starter fluid is sprayed into air intake. if it is turned off it will not restart without starter fluid. it was running fine after a new fuel pump , fuel pressure sensor , and distributor cap and rotor.
what could be wrong ?
1 thought on “chevrolet blazer”
  1. Next time you go to start it try holding your foot all the way to the floor.. if it starts easier you may need to replace the IAC Valve(Idle Air Control).
    If it is of no help, look at the fuel pressure regulator… You can cycle the key on and off several times before you try to start it to see if the fuel pressure has been bleeding off…..
