You will need to press the “RESET” button after you fix the short in the speaker wiring which is why it is in PROTECT Mode. The reset button on non-removable face plates is just below the volume knob and Behind the face plate on removable styles. You will need a pin or tooth pic to press in the tiny black button. Then your good to go. If it still flashes after pressing the reset button, then you need to re-check your wiring again for a short.
