Home » Car Questions » pontiac bonnieville 97 will not go into any gear
1 thought on “pontiac bonnieville 97 will not go into any gear”
  1. First Check Transmission Fluid Level with Engine running. If it is full, Note the color. If it is black/burnt and full then you are looking at a new/rebuilt transmission.
    If the fluid is full and fluid looks nice and pink, then you are looking at a linkage problem or an internal shift solenoid problem…
    If the fluid is not full you may need to repair the leak and then top off the fluid level.
