“I have an 1996 Chev Monte carlo 3.1 it just started shutting down on me, It starts up fine, while in park it runs fine, I can even drive it for about 10 block then it just shut down, I had the fuel pump and filter changed and it still dose it what can it b …”
1996 Chev Monte Carlo
Is the Check Engine Light On? If So have you pulled the codes yet? and what are they?
Does the engine have Spark or Injection Pulse?
http://www.freeautomechanic.com/nostart.html
I had the same year monte carlo and it did the same thing I replaced the fuel pump , and blew out fuel lines and inline fuel filters that was not the problem . The problem was in the sock filter located in the back of the gas tank which is not visiable you have to drop the gas tank. just a suggestion
