Home » Car Questions » 1996 Chev Monte Carlo
“I have an 1996 Chev Monte carlo 3.1 it just started shutting down on me, It starts up fine, while in park it runs fine, I can even drive it for about 10 block then it just shut down, I had the fuel pump and filter changed and it still dose it what can it b …”
2 thoughts on “1996 Chev Monte Carlo”
  1. I had the same year monte carlo and it did the same thing I replaced the fuel pump , and blew out fuel lines and inline fuel filters that was not the problem . The problem was in the sock filter located in the back of the gas tank which is not visiable you have to drop the gas tank. just a suggestion
