I was spun around on a snowy road and while sliding hit dry concrete. my vehicle jolted and the steering wheel locked up. now its stuck and hardly moves at all. I tried changing back to two wheel drive and then back to four but still nothing. When i back up it steers right and when i steers left..
2003 gmc envoy steering issues
Sounds like you bent something pretty good in the steering linkage, you will need to jack up the front end see what exactly is bent and replace as needed. An alignment when your done wouldn’t be a bad idea either.
