headlights go out randomly i can use manual switch or high beam switch a few times and they come back on can you help me with this… very dangerous as i drive at night most of the time…
Keywords:impala
sounds like you could have a loose ground wire… perform wiggle test or a loose connection at the battery… if these are both ok, use a multi-meter to test the light switch.
http://www.freeautomechanic.com/wiringproblems%206.html
I have a 2001 chevy impala that will not start. I replaced the ignition switch in the spring. Are there any problems in the harness of the ignition switch that can be repaired? I’ve been told that this can only be repaired at a dealer and that this is a common problem with the ignition assembly in this model.
