Home » Car Questions » 98 blazer wont start after oil line blew
i have a 98 blazer i was driving it last night and the oil cooler line blew and the check guages light came on oil pressure dropped to zero and the truck lost power and shut off.. i rolled it into a parking lot and got the line fixed and filled back up with oil and now the truck will not start… i changed the battery out thinking it was that then changed the starter relay out as well the truck just makes one solid click noise
1 thought on “98 blazer wont start after oil line blew”
  1. Engine is most likely locked up…. put a wrench on the end of the crankshaft and see if you can turn it in either direction…removal of serpentine belt makes this an easier task. If you can’t turn it by hand, the engine is locked up.
    If the engine spins freely with a wrench , then you will need to replace the starter most likely.
